NetApp Knowledge Base
What are the mount options for SAP MaxDB on NetApp NFS?
561
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • Data ONTAP operating in 7-Mode
  • ONTAP 9
  • NFS
Answer
  • SAP MaxDB or SAPDB Version 7.5 or higher
    • Operating System Mount Options for Binaries Mount Options for MaxDB Data and Log Volumes
      Solaris [common],proto=tcp [common],proto=tcp,[forcedirectio or llock]
      AIX [common],proto=tcp,timeo=600 [common],proto=tcp,timeo=600,cio
      HPUX [common],proto=tcp,timeo=600 [common],proto=tcp,timeo=600
      Linux [common],tcp,timeo=600 [common],tcp,timeo=600
    • [common] = rw,bg,hard,nointr,rsize=32768,wsize=32768,vers=3,suid
    • [common] = These mount options should be used in addition to the ones in the matrix.
Additional Information
additionalInformation_text
