What are the flow control best practices for Ethernet?
Applies to
Data ONTAP
Answer
Best Practices:
Follow flow control best practices when experiencing excessive pause frames, xon / xoff frames, or packets being re-queued, as seen in ifstat -av.
- interface e1a (0 hours, 0 minutes, 40 seconds) --
RECEIVE
Frames/second: 1568 | Bytes/second: 27607k | Errors/minute: 0
Discards/minute: 0 | Total frames: 248k | Total bytes: 4222m
Total errors: 0 | Total discards: 0 | Multi/broadcast: 2
No buffers: 0 | Non-primary u/c: 0 | LRO segments: 172k
LRO bytes: 3929m | L2 terminate: 0 | Tag drop: 0
Vlan tag drop: 0 | Vlan untag drop: 0 | Vlan forwards: 0
Vlan broadcasts: 0 | Vlan unicasts: 0 | CRC errors: 0
Runt frames: 0 | Fragment: 0 | Long frames: 0
Jabber: 0 | Bus overruns: 0 | Queue drop: 0
Xon: 25 | Xoff: 25
| Jumbo: 68353
No buf hi: 0
TRANSMIT
Frames/second: 1055 | Bytes/second: 154k | Errors/minute: 0
Discards/minute: 0 | Total frames: 166k | Total bytes: 44356k
Queue overflows: 0 | No buffers: 0 | Frames queued: 0
Buffer coalesces: 854 | MTUs too big: 0 | TSO segments: 0
TSO bytes: 0 | TSO6 segments: 0 | TSO6 bytes: 0
LTM fastp calls: 166k | LTM busy calls: 0 | LTM update calls: 160
LTM yield calls: 0 | LTM drain rss: 0 | LTM total calls: 166k
Xon: 0 | Xoff: 0 | Jumbo: 3765
TSO non-TCP drop: 0 | Split hdr drop: 0 | Pktlen: 0
Timeout: 0 | Timeout1: 0
LINK_INFO
Current state: up | Up to downs: 6 |
Speed: 10000m
Duplex: full |
Flowcontrol: full
RSS
Itable updates: 0 | Hash errors: 0
Queue 0
Tx frames: 11780 | Tx bytes: 22306k | Rx frames: 59
Rx bytes: 103k | Requeued: 0 | Hi pri intr: 10735
Queue 1
Tx frames: 1073 | Tx bytes: 143k | Rx frames: 4484
Rx bytes: 33895k | Requeued: 3165 | Hi pri intr: 4160
Queue 2
Tx frames: 306 | Tx bytes: 33404 | Rx frames: 3469
Rx bytes: 3539k | Requeued: 3007 | Hi pri intr: 3831
Queue 3
Tx frames: 153k | Tx bytes: 21872k | Rx frames: 240k
Rx bytes: 4184m | Requeued: 801 | Hi pri intr: 143k
7-Mode Flow control recommendations:
Ensure that the flow control interface option is disabled on the storage controller on interfaces using 10g Ethernet.(The host might follow its own best practices, such that the flow control is enabled on the host end using send/receive as needed; however, this is outside of the scope of this article.)
The defined multicast MAC address: 01-80-C2-0-0-01 sends the PAUSE frames, including the pause frame length.
This works at the physical link layer. None of the upper level protocols are considered, which can potentially affect the overall performance of TCP by inducing an artificial delay between router hops, while also having the effect of decreasing the window size due to dropped packets. In large networks, congestion trees can form, which can severely limit the overall network throughput for all attached devices on the network.
It is not recommended to enable flow control throughout the network, including intracluster ports, data switches, and data ports.
Flow control settings by default are set to on for both send and receive flow control for backward compatibility.
Configuring the send and receive flow control to be disabled will need to be set from the ifconfig
command and saved to the /etc/rc
file to be made persistent.
Example: ifconfig e0a flowcontrol none
Clustered Data ONTAP / ONTAP 9 Flow control recommendations:
It is recommended to match the flow control setting throughout each network path, including intercluster ports, data switches, and data ports. (excluding intracluster /cluster network ports)
A subsequent effort by Cisco, priority flow control (defined in IEEE 802.1Qbb), was intended to replace802.3x PAUSE and provide a mechanism that could be controlled independently for each class of service defined by IEEE802.1p. Instead of pausing all traffic on a network link, priority flow control allows the administrator to selectively pause traffic according to its class of service.
Historically (7-Mode/clustered Data ONTAP), NetApp had recommended that flow control be disabled on all network ports within a NetApp Data ONTAP cluster. This approach is no longer the case. Guidance in this area has since changed, the new recommended best practice is as follows:
- Disable flow control on cluster network ports in the Data ONTAP cluster.
- Flowcontrol on the remaining network ports (the ports that provide data, management, and intercluster connectivity) should be configured to match the settings within the rest of your environment.
Additional Information
N/A
