NetApp Knowledge Base
CPU utilization above 50 percent before upgrading ONTAP
6,920
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • Digital Advisor
  • Upgrade Advisor
  • ONTAP Upgrades
Issue
  • Upgrade Advisor presents the storage admin with the following task as part of an ONTAP upgrade:
    • Determine the CPU and disk utilization:
node run -node node_name -command sysstat -c 10 -x 3
  • You should monitor CPU and disk utilization for 30 seconds. The values in the CPU  and Disk Util  columns should not exceed 50% for all 10 measurements reported
  • No additional load should be added to the cluster until the upgrade is complete
New to NetApp?
