NetApp Knowledge Base
Is it possible to modify the volume from writeable to readonly?
5,798
Visibility:
Votes:
3
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
ONTAP 9
Answer
It's not possible to modify the volume from writeable(RW) to readonly(DP) directly
There are two ways to make the volume into a DP volume:
  • Create a volume with DP type:
::> volume create -volume volname -vserver svm1 -type DP
  • Resync a SnapMirror relationship, the destination volume becomes DP type.
Snapmirror resync operation can delete data in the destination volume, make sure the resync volume is correct or not.
::> snapmirror show
        Progress
Source            Destination Mirror  Relationship   Total             Last
Path        Type  Path        State   Status         Progress  Healthy Updated
svm1:vol1  XDP  svm1:vol1dp  Snapmirrored
                                      Idle           -         true    -
::> volume show -volume vol1dp
Vserver   Volume       Aggregate    State      Type       Size  Available Used%
svm1      vol1dp       aggrfp       online     DP        500MB    195.9MB   60%
::> snapmirror break -destination-path svm1:vol1dp
Operation succeeded: snapmirror break for destination "svm1:vol1dp".
svm1      vol1dp       aggrfp       online     RW        500MB    194.8MB   61%
::> snapmirror resync -destination-path svm1:vol1dp
Warning: All data newer than Snapshot copy snapmirror.xxxxxx.xxxx-xx-xx_xxx on volume svm1:vol1dp will be deleted.
Do you want to continue? {y|n}: y
Operation is queued: initiate snapmirror resync to destination "svm1:vol1dp".
corecls9701::> volume show -volume vol1dp
Additional Information
N/A
