How to throttle volume move in ONTAP 9.10 or later
Applies to
ONTAP 9.10 or later
- By default,
vol move
will use any resources available to it - In some scenarios, it is desirable to limit the bandwidth consumed by vol move operations
- ONTAP 9.10 and later add a new
-enforce-network-throttling
option forvol move
- Used in conjunction with the
replication.throttle.*
options,-enforce-network-throttling
will apply node-level network throttle to a volume move job - The throttle will leave more resources available for other operations using the same resources
