NetApp Knowledge Base
How to set ONTAP to use LDAP Signing or Sealing for CIFS/NFS
21,520
Visibility:
Votes:
9
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • Common Internet File System (CIFS)
  • Network File System (NFS)
  • Lightweight Directory Access Protocol (LDAP)
  • Beginning in ONTAP 9, you can configure signing and sealing to enable LDAP session security on queries to an Active Directory (AD) server.
    • You must configure the CIFS server security settings on the storage virtual machine (SVM) to correspond to those on the LDAP server.
    • Signing confirms the integrity of the LDAP payload data using secret key technology.
    • Sealing encrypts the LDAP payload data to avoid transmitting sensitive information in clear text.
  • An LDAP Security Level option indicates whether the LDAP traffic needs to be signed, signed and sealed, or neither. The default is none.
  • Setting these options are expected to be non-disruptive operations. Existing cifs\nfs connections will not be impacted by this change: More information
New to NetApp?
