NetApp Knowledge Base
How to customize ONTAP CLI output formats for importing into Excel
4,293
Visibility:
Votes:
0
Category:
clustered-data-ontap-8
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
Clustered Data ONTAP allows the CLI output format to be customized. By using the set command, it is easy to set the CLI parameters that allow pasting into Excel for additional manipulation, or for use in documentation.
New to NetApp?
