NetApp Knowledge Base
How do the NFSv4 grace periods work
5,499
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • NFSv4
Answer
There are two NFSv4 related grace periods:
  1. When a LIF is moved to another node, NFSv4 clients can reclaim locks for the duration specified in the NFS option -v4-grace-seconds
  2. When an aggregate is relocated to another node, NLM lock reclamation takes place for the duration specified by the locking.grace_lease_seconds node level option
Note: The NFSv3 access will be affected by this as well
Note: During either of these periods, NFSv4 clients cannot obtain new locks
Additional Information
  • After a takeover, the two periods may overlap
  • On a giveback, interfaces are reverted independently from the time aggregates are relocated and both periods may be observed individually
  • Depending on the timing of how clients retry NFS calls, client applications may experience longer I/O delays than the grace periods themselves
  • TR-4067
