NetApp Knowledge Base
Data ONTAP 8: How does disk ownership of NetApp Shared Storage work and what are the requirements?
2,264
Visibility:
Votes:
1
Category:
data-ontap-8
Specialty:
7dot
Last Updated:
Applies to
  • Clustered Data ONTAP 8
  • Data ONTAP 8 7-Mode
Answer
Disk ownership of NetApp Shared Storage
Assign or show disk ownership of a NetApp Shared Storage
Disks need to be assigned after being replaced
What are the requirements for enabling sanown / software disk-based ownership?
NetApp Shared Storage follows the software-based ownership model. The basics of the ownership model are:
  • Disks are explicitly assigned to a storage system
  • Ownership information is written to the disk
  • Once assigned, storage systems use reservations to keep other storage systems from touching the disk
  • Some disks may stay unowned. Unowned disks will not have new firmware downloaded
  • Disks must be assigned to be used as a spare
The requirements for enabling software ownership (sanown) are:
  • A Data ONTAP version that supports sanown
  • CompactFlash boot based filer
  • DS14, DS14mk2 shelf
To assign disk ownership of a NetApp Shared Storage:
  • Data ONTAP 8 7-Mode:
disk assign <diskname> [-f] [-p  ] [- o <ownername>] [-s <sysid>]
    1. Normal usage is to assign ownership of unowned disks to local storage system:
disk assign 0b.16
disk assign 0b.17 -p 1
    1. To assign disk owned by local storage system back to unowned:
disk assign 0b.16 -s unowned -f
    1. To assign ownership to another storage system:
disk assign 0b.16 -o otherguy -f
Should use higher-level functionality (vFiler migrate) to do this, unless disk is a spare
    1. If receiving storage system is unable to communicate with the donor storage system, there will be warnings about rescan messages.
  • Data ONTAP 8 Cluster-Mode:
    'disk reassign' is an advanced command.
::> set adv
::*> disk reassign ?
  (storage disk reassign)
  [[-home] <text>]            Current Home Name
  [ -newhome <nodename> ]     New Home Name
  [ -homeid <nvramid> ]       Current Home ID
  [ -newhomeid <nvramid> ]    New Home ID
  [ -force [{true|false}] ]   Force
To display the disk ownership of a NetApp Shared Storage:
disk show [-o <hostname> | -s <sysid> | -n | -v | -a ]
Display information for disks:
  • with matching owner name
  • with matching system id
  • not owned by any system
  • verbose listing of all disks
  • owned by any storage system
For example, seeing every disk's ownership:
cfo-u37> disk show -v
DISK         OWNER                  POOL   SERIAL NUMBER
9b.19        cfo-u37   (50408384)   Pool0  3HZ6RA1B00007426SWC9
8b.107       cfo-u39   (50408359)   Pool0  3HZ6SF3L000074289QWS
2b.49        cfo-u38   (50408371)   Pool0  3HZ6SD55000074289R4R
3a.22        cfo-u37   (50408384)   Pool0  3HZ6YDGM000074310Z3A
9b.68        cfo-u39   (50408359)   Pool0  3HZ6SEGL00007428B70G
8a.20        cfo-u39   (50408359)   Pool0  3HZ6P9PG0000740529DS
3b.99        cfo-u36   (50408412)   Pool0  414R6372
3b.108       cfo-u36   (50408412)   Pool0  414W6158
3b.98        cfo-u36   (50408412)   Pool0  414W5818
3b.49        cfo-u36   (50408412)   Pool0  413M5089
::> disk show
Available options are :
  (storage disk show)
  [ -classic | -instance | -longop | -physical | -port | -raid | -sanown |
    -v | -fields <fieldname>, ... ]
  [[-disk] <disk path name>]                   Disk
  [ -physicalsize <integer> ]                  Physical Size (MB)
  [ -usedsize <integer> ]                      Used Size (MB)
  [ -type <disk type> ]                        Type
  [ -vendor <text>]                            Vendor
  [ -serialnumber <text> ]                     Serial Number
  [ -model <text> ]                            Model
  [ -revision <text> ]                         Firmware Revision
  [ -rpm <integer> ]                           RPM
  [ -bps <integer> ]                           Bytes Per Sector
  [ -checksum <text> ]                         Checksum Compatibility
  [ -shelf <integer> ]                         Shelf
  [ -bay <integer> ]                           Bay
  [ -state <disk state> ]                      State
  [ -detailstate <text>]                       Detail State
  [ -raidtype {pending|parity|dparity|data} ]  Raid Type
  [ -raidgroup <text> ]                        Raid Group
  [ -plex <text> ]                             Plex
  [ -aggregate <aggregate name> ]              Aggregate
  [ -home <nodename> ]                         Home
Additional Information
N/A
