Cluster peer errors on node cause vifmgr and mgwd to restart
Applies to
- ONTAP 9.6
- ONTAP 9.7
Issue
- In clusters running ONTAP 9.6 or 9.7, cluster peer errors are generated at random times:
[node-01: mgwd: cpeer.xcm.update.warn:error]: Periodic update of peer network information failed. The following operations are incomplete: discovery failure.
[node-01: mgwd: cpeer.xcm.addr.disc.warn:error]: Address discovery failed for peer cluster 15897456-d9fg-11e7-9c45-xfghdfgsgheds. Reason: Failed to discover remote addresses: Timeout: Operation "clusterPeer_rtable_iterator::get_imp()" took longer than 60 seconds to complete [from mgwd on node "node-01" (VSID: -3) to mgwd at 15897456-d9fg-11e7-9c45-xfghdfgsgheds].
[node-01: mgwd: cpeer.ping.no.lifs:error]: Failed to find intercluster LIFs in IPspace Default on node node-01.
[node-01: mgwd: cpeer.xcm.update.warn:error]: Periodic update of peer information from CLUSTERNAME failed. The following operations are incomplete: The identity of peer cluster 15897456-d9fg-11e7-9c45-xfghdfgsgheds not found.- This may lead to
vifmgrandmgwdrestart on the node causing the data LIFs to migrate. - If failover targets are not configured properly, this may lead to a data outage.
