AutoSupports fail after an AFF/FAS reboot in ONTAP 9.6 and Later
Applies to
- ONTAP 9.6 and greater
- Following a reboot
- normal reboot
- HW replacement
Issue
- After rebooting ONTAP Autosupports are failing to be sent
cluster1::> autosupport history show
Seq Attempt Percent Last
Node Num Destination Status Count Complete Update
cluster1-01 2
smtp ignore 1 - 9/28/2020 09:18:05
http transmission-failed 15 - 9/28/2020 11:14:19
noteto ignore 1 - 9/28/2020 09:18:05
1
smtp ignore 1 - 9/28/2020 09:22:15
http transmission-failed 15 - 9/28/2020 10:18:17
noteto ignore 1 - 9/28/2020 09:22:15
