NetApp Knowledge Base
Expired certificates for SSL/TLS cause secd.ldap.noServers
9,196
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP
  • Third party LDAP servers
  • SSL/TLS
Issue
  • After enabling SSL/TLS on the already existing LDAP configuration storage access may be impacted as connection to the LDAP server fails
  • EMS logs:
secd.ldap.noServers: None of the LDAP servers configured for Vserver (VS1) are currently accessible via the network for LDAP service type (Service: LDAP (Active Directory), Operation: SiteDiscovery).
secd.ldap.noServers: None of the LDAP servers configured for Vserver (VS1) are currently accessible via the network for LDAP service type (Service: LDAP (Active Directory), Operation: MapNetbiosDomainToADDomain).
  • Secd logs:
error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
RESULT_ERROR_LDAPSERVER_SERVER_DOWN:7642
LDAP TLS Alert generated is 'fatal:decrypt error'
error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01
RESULT_ERROR_LDAPSERVER_CONNECT_ERROR:7652
secd: secd.unexpectedFailure:debug]: vserver (VSERVER) Unexpected failure.
Error: Get DC Info procedure failed CIFS Domain Query via LSAR_DS_ROLE_GET_DOMAIN_INFO - Client Ip = X.X.X.X
User = DOMAIN\USER   ...
[   236] Successfully connected to ip X.X.X.X, port 389 using TCP
[   377] Unable to start TLS: Connect error
[   377]   Additional info: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed (certificate has expired)
  • Secd log entry will contain the subject of the expected certificate
00000013.0022c89e 01eab99b Mon Apr 06 2020 14:31:44 +01:00 [kern_secd:info:14641] | [000.499.972]  info :  Required certificate with <CANAME> is not installed { in VerifyCertificateRevocationViaOSCP() at src/connection_manager/secd_connection.cpp:1667 }
  • Expiration date indicate expiry in CLI command:  ::> security certificate show
  • Packet trace can show the full certificate chain is provided by the client
Example of LDAP server provides a certificate chain composed of two certificates
  • One is the certificate of the of the host itself (LDAPserverhostname, issued by issuer CA),
  • Other, an intermediate certificate (Issuer CA issued by Root CA)
Transport Layer Security
    TLSv1.2 Record Layer: Handshake Protocol: Multiple Handshake Messages
        Content Type: Handshake (22)
        Version: TLS 1.2 (0x0303)
        Length: 2911
        Handshake Protocol: Server Hello
        Handshake Protocol: Certificate
            Handshake Type: Certificate (11)
            Length: 2587
            Certificates Length: 2584
            Certificates (2584 bytes)
                Certificate Length: 1208
                Certificate: 308204b43082039ca0030201020213160000802cf3c5747b… (id-at-commonName=LDAPserverhostname)
                    signedCertificate
                        version: v3 (2)
                        serialNumber: 0x160000802cf3c5747b5475eb2100000000802c
                        signature (sha256WithRSAEncryption)
                        issuer: rdnSequence (0)
                            rdnSequence: 3 items (id-at-commonName=Issuer CA )
                        validity
                        subject: rdnSequence (0)
                        subjectPublicKeyInfo
                        extensions: 9 items
                    algorithmIdentifier (sha256WithRSAEncryption)
                    Padding: 0
                    encrypted: d403151937a2904d0405e5fe7be043a51969650e43cc27e0…
                Certificate Length: 1370
                Certificate: 308205563082033ea00302010211114500000002578509d7… (id-at-commonName=Issuer CA )
                    signedCertificate
                        version: v3 (2)
                        serialNumber: 0x4500000002578509d77c523cae000000000002
                            rdnSequence: 3 items (id-at-commonName=Root CA)
  • In this example, root certificate for Root CA must be installed
New to NetApp?
