What is E-Series SMI-S Array Management Utility error code 10?
- 200
- Visibility:
- Public
- Votes:
- 0
- Category:
- e-series-santricity-smi-s-provider
- Specialty:
- esg
- Last Updated:
Applies to
E-Series
Answer
When trying to add a storage system to the E-Series SMI-S Provider using the Array Management Utility software, the utility performs a communication check with the storage system prior to adding the system to the Provider. If the communication test does not pass, then a code 10 will be returned.
Check to make sure network traffic can pass to the storage systems from the SMI-S Provider server. Port 2463 needs to be open, as the Provider uses it to communicate to the storage systems.
Additional Information
Add your text here.
