SnapManager Suite
- Last updated
- Jan 6, 2020
- Save as PDF
This guide provides an overview of product features and related technologies. In addition, it contains recommendations on best practices, tutorials for getting started, and troubleshooting information for common situations.
Most popular
(views)- What NTFS allocation unit size should be used for LUNs for Microsoft SQL Server and Microsoft Exchange?
- Snapshots display Stale NFS file handle message
- How to address Common VSS errors from failed SnapManager for Exchange backups
- SnapManager for Exchange is unable to see database after Exchange Security update KB5001779
- How to set up SVM/CIFS for Hyper-V over SMB
- ORA-01017 invalid username password; logon denied using database authentication
- How to increase the maximum queue depth per Logical Unit Number (LUN) in Windows with QLogic MC and Emulex Host Bus Adapter (HBAs)
- How to collect SMO/SMSAP dumps using the GUI or CLI
- SnapManager backups fail with error “VSS_E_VOLUME_NOT_SUPPORTED_BY_PROVIDER” after SnapCenter plugin is deployed
- SnapDrive fails to interact with ReFS LUN
- Is SnapManager for Oracle or SAP compatible with Oracle 18c or 19c ?
- SnapDrive failed to discover storage resource leading to failure of SnapManager backups with error code "SD-10016"
- Where is the location to download SnapDrive?
- Unable to add SM destination SVM to SDW: Unable to modify or add transport protocol. Failed to get Data ONTAP version running on the storage system
- SMSQL backup fails with Error "Disk(s) used by this database are used by other database(s)"
Highest rated
(rating)- SMO/SMSAP profile deletion fails with an SD-10014: unexpected snapdrive error
- SMHV keeps expired backup Snapshot after failing to delete
- SnapDrive for Windows (SDW) console crashes when SVM is added to Transport Protocol Settings
- SMSQL-Snapshot operation not allowed due to clones backed by snapshots
- 'Transport Protocol is not set to connect the storage system %1' when SME verification runs in Metrocluster switchover mode
- Snap Manager for SQL backups fail with error A nonrecoverable I/O error occurred
- SnapManager for Oracle clone fails with error: online backup of file 1 needs more recovery to be consistent
- SnapDrive for UNIX Error: EXE-00003: Killing spawned process for command: /usr/sbin/snapdrive snap create
- SMHV backup tasks failed because of licensing problems
- SMHV fails to restore LUNs in a semi-thick volume
- SnapDrive for Windows causing many "Event 81" errors
- SME backup fails with the error"please check to see if there is enough free disk space in the snapinfo directory"
- SnapManager for Oracle GUI does not allow for login
- SnapManager for Hyper-V triggers backup jobs multiple times in a day
Recently updated
(date updated)- SMHV backup fails because VM is recognized by multiple hosts
- How to manually complete SnapManager for Virtual Infrastructure (SMVI) SFR or manually mount VMDK from Network File System (NFS) snapshot
- Can domain user be used as User of Storage Connection Settings in SMHV?
- SnapManager for Hyper-V backup failed with error: Could not find owner of VM
- SMHV fails to restore VMs due to the error “Failed to retrieve virtual machines”
- When a backup targeting a single VM fails in SnapManager for Hyper-V , a snapshot named as UUID remains on the volume
- The SnapManager for Hyper-V backup fails with a VSS_E_WRITERERROR_NONRETRYABLE
- SMHV backup fails by service connection failure during Windows maintenance
- SMHV backup failed for Hyper-V host
- Is it possible to perform SMHV restore by Snapshot which is not managed by SMHV?
- Does the backup of the dataset rotate correctly when there is a VM that cannot be backed up successfully?
- SnapDrive for Windows fails to create Snapshots for LUNs on ONTAP 9.13.1
- SMHV fails to run configuration wizard with the error Failed to establish connection to net.tcp
- SMHV reports an issue connecting to a host
- How to upgrade SMHV
Recently added
(date created)- Can domain user be used as User of Storage Connection Settings in SMHV?
- How to determine SnapManager for Hyper-V (SMHV) version from build number
- SDW cannot find a path to the LUN
- SnapDrive for Unix fails to create snapshots for LUNs on ONTAP 9.13.1
- SMHV failing on removing snapinfo folders
- Is a reboot required when uninstalling SnapDrive for Windows?
