Attempts to add a cluster in OnCommand Workflow Automation results in error "Credential with expired certificate is not testable."
- 586
- Visibility:
- Public
- Votes:
- 2
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- legacy
- Last Updated:
Applies to
- OnCommand Workflow Automation 5.x
Issue
When attempting to add a cluster in OnCommand Workflow Automation, and choosing the option Test to validate credentials, the following error prompt returns with the message:
The corresponding message below is also found in the wfa.log:
Failed to get connection from data-source
Caused by: com.netapp.wfa.util.SqlShellException: Failed to get connection from data-source
Caused by: java.sql.SQLInvalidAuthorizationSpecException: Could not connect: Access denied for user 'admin'@'server.company.com' (using password: YES)
