Importing a storage volume with a replacement PVC fails in Trident as Bad Request
Applies to
Trident for Kubernetes or Openshift
Issue
When trying to change the definition of the Persistent Volume Claim (PVC) for existing Persistent Volumes (PVs) in Trident, the import command fails with:
Error: could not import volume: frontend failed to import volume:PV <PV_NAME> already exists for volume <VOLUME> (400 Bad Request)
command terminated with exit code 1
