NetApp Knowledge Base
How to enable Trident debug and debugTraceFlag for more verbose logging
2,566
Visibility:
Votes:
0
Category:
astra_trident
Specialty:
snapx
Last Updated:
Applies to
NetApp Astra Trident
  • For Trident installed with the operator, enabling Trident debug requires setting 2 flags:
1. Set the 'debug' flag for the Trident pods in the deployment
2. Set the 'debugTraceFlag' on a specific trident backend.
    When debug is not enabled, you will see mostly 'level=info' messages.  With debugging enabled, you will see 'level=debug' msg messages.
  • For Trident installed using helm , you need to  use the flag --set tridentDebug=true
  • For Trident installed using "tridentctl install ... " command, you will need to uninstall trident and then install it again, with the -d flag:
New to NetApp?
