ONTAP Select Single node cluster not seen as part of the cluster after power cycle
Applies to
- ONTAP Select single-node cluster
- ONTAP 9.16.1
- VMware ESXi hypervisor environment
Issue
- The cluster was down for an extended period, and the power-off cause is unknown.
- After powering theONTAP Select single node cluster, the following symptoms are observed:
- Only management connectivity (mgmt LIF) is available
- System Manager access is not possible.
- No SVMs/vServers, volumes, data LIFs, or cluster LIFs are visible from the ONTAP CLI.
- The node is not seen as part of the cluster, and cluster-related CLI commands are unavailable.
- CLI commands such as
cluster show,vserver show, andvolume showreturn:Error: "show" is not a recognized command
