Is possible to use SQL volume read_only to prevents LUN offline due to space error
Applies to
- ONTAP 9
- SQL database
Answer
- No, SQL database requires read/write volume
- If the volume is running out of space, it is required to check / adjust the configuration of the volume containing the LUN, to avoid LUN goes offline with space-error
