NetApp Knowledge Base
Unable to migrate Array LUN greater than 16TB using FLI
913
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9
  • Foreign LUN import (FLI)
Issue
  • You see the following error in storage errors show for an array LUN greater than 16TB:
Disk: DGC-1.x
UID: 600601xx:E1BxxE00:412336xx:3D4DxxCE:00000000:00000000:00000000:00000000:00000000:00000000
This array LUN is too large and is not usable. The maximum array LUN size supported is 16000 GB.
  • storage disk show reports the disk in "broken" state:
CxL-NExxxP-xxx::*> storage disk show -array-name DGx_LUxZ_1 -fields disk,serial-number,container-type,owner,path-lun-in-use-count,import-in-progress,is-foreign
disk    owner is-foreign container-type import-in-progress path-lun-in-use-count serial-number
DGC-1.4 -     false      broken         false              0,0,0,0               6006xx604BB1490xxxD44E5C9E172DED
  • Setting the environment variable value in nodeshell did not resolve the issue
New to NetApp?
