NetApp Knowledge Base
Path redundancy degraded alerts receiving continuously on ESXi host side
1,236
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9
  • FC LUNs
  • ESXi host
  • Brocade switch
Issue
  • ESXi host continuously getting below alert on VMware side.
Alarm alarm.StorageConnectivityAlarm on Host hostabc.xxx.com
because Path redundancy to storage device naa.600a098xxxxxx46c3f515xxxxxxxx degraded. Path vmhba2:C0:xx:xx0 is down. Affected datastores: xxx-NetApp-xyz..
Alarm name  alarm.StorageConnectivityAlarm
Description alarm.StorageConnectivityAlarm
Target      Host hostabc.xxx.com
Triggered time    04/10/2023 10:40:57 AM
  • FC LUNs are mapped to these hosts from NetApp storage.
  • There are no disruptions seen at host side due to these alerts.
  • Alerts are being generated very frequently at host side almost 3 hours or so.
  • LUNs at storage side are online, mapped and no errors observed in EMS logs during the issue timestamp.
  • FC ports are all up and Rx, Tx values are in optimal range.
  • Brocade switch log analysis indicated an issue with port between switch & NetApp storage.
  • Switchshow reports the port as online
/fabos/bin/switchshow :
Index Port Address  Media Speed   State       Proto
   9   9   020900   id    N8   Online      FC  F-Port  1 N Port + 1 NPIV public
  • Porterrshow indicates multiple media errors are reported for the port.
/fabos/cliexec/porterrshow :
          frames      enc    crc    crc    too    too    bad    enc   disc   link   loss   loss   frjt   fbsy  c3timeout    pcs    uncor
       tx     rx      in    err    g_eof  shrt   long   eof     out   c3    fail    sync   sig                  tx    rx     err    err
  9:    3.4g   1.5g  39.4k  30.9m  30.5m   0     11.3k 454.4k   2.1m  79.2k 206      0      2.4k   0      0      0      0    264.1m   0
  • Under sfpshow it is observed that Rx value is not in optimal range whereas Tx value is in optimal range.
Port  9:
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 7004404000000000 4,8,16_Gbps M5 sw Short_dist
Vendor Name: HP-F     BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   QK724A
RX Power:    -12.1   dBm (61.0 uW)
TX Power:    -3.2    dBm (483.8 uW)
  • Portstatsshow indicates that port encountered multiple issues.
portstatsshow 9
fec_cor_detected        0                   Count of blocks that were corrected by FEC
fec_uncor_detected      0                   Count of blocks that were left uncorrected by FEC
er_enc_in               39648               Encoding errors inside of frames
er_crc                  30968151            Frames with CRC errors
er_trunc                0                   Frames shorter than minimum
er_toolong              11379               Frames longer than maximum
er_bad_eof              454430              Frames with bad end-of-frame
er_enc_out              2172705             Encoding error outside of frames
er_bad_os               3801509             Invalid ordered set
er_pcs_blk              264192520           PCS block errors
er_rx_c3_timeout        0                   Class 3 receive frames discarded due to timeout
er_tx_c3_timeout        0                   Class 3 transmit frames discarded due to timeout
er_unroutable           20153               Frames that are unroutable
er_unreachable          0                   Frames with unreachable destination
er_other_discard        79253               Other discards
er_type1_miss           0                   frames with FTB type 1 miss
er_type2_miss           0                   frames with FTB type 2 miss
er_type6_miss           0                   frames with FTB type 6 miss
er_zone_miss            71                  frames with hard zoning miss
er_lun_zone_miss        0                   frames with LUN zoning miss
er_crc_good_eof         30502349            Crc error with good eof
er_inv_arb              0                   Invalid ARB
er_single_credit_loss   0                   Single vcrdy/frame loss on link
er_multi_credit_loss    0                   Multiple vcrdy/frame loss on link
other_credit_loss       0                   Link timeout/complete credit loss
phy_stats_clear_ts      06-23-2022 UTC Thu 14:06:23      Timestamp of phy_port stats clear
lgc_stats_clear_ts      06-23-2022 UTC Thu 14:06:23      Timestamp of lgc_port stats clear
  • Fabriclog indicates the port flapped multiple times.
Switch 0; Mon Apr 10 09:34:46 2023 GMT (GMT+0:00)
09:34:56.224522 SCN Port Offline;rsn=0x2,g=0xc0             D0,P0  D0,P0  9     NA
09:34:56.224540 *Removing all nodes from port               D0,P0  D0,P0  9     NA
09:35:08.666250 SCN LR_PORT(0);g=0xc0                       D0,P0  D0,P0  9     NA
09:35:08.671197 SCN Port Online; g=0xc0,isolated=0          D0,P0  D0,P1  9     NA
09:35:08.671407 Port Elp engaged                            D0,P1  D0,P0  9     NA
13:00:36.370320 SCN Port Online; g=0xc4,isolated=0          D0,P0  D0,P1  9     NA
13:00:36.370531 Port Elp engaged                            D0,P1  D0,P0  9     NA
13:00:36.370601 *Removing all nodes from port               D0,P0  D0,P0  9     NA
13:00:36.370803 SCN Port F_PORT                             D0,P1  D0,P0  9     NA
13:11:22.396502 SCN LR_PORT(0);g=0xc4 LR_IN                 D0,P0  D0,P0  9     NA
New to NetApp?
