ONTAP FC port shows low receive power (RX) value
Applies to
- ONTAP
- FCP
- Brocade SAN switch
- Cisco SAN switch
Issue
- FC port shows low RX value on ONTAP as per
fcp adapter showoutput:
::> fcp adapter show -instance -node nodename -adapter 0a
Received Optical Power: 241.3 (uWatts)
Is Received Power In Range: false
SFP Transmitted Optical Power: 600.4 (uWatts)
Is Xmit Power In Range: true
DDM Status: 30
Is Xmit Disabled: false
Is Xmit In Fault: false
Is Receiver In LOS: false
FCP-Adapter.xmllog on ONTAP reports low Rx power , indicating issue upstream to Ontap:
- Below risk is reported in AIQM-
RISK: SFP receive power of the SFP connected to netapp port 9c is below the recommended value.
• The sfp looks good on both ends. Tx and Rx both are within the recommended range on both ends.
- In
EMSlogs we observedlink break detectedandlink uperrors along withAENerrors:
Wed Apr 12 03:42:08 +0200 [nxx-0x: fct_tpd_work_thread_0: scsitarget.slifct.linkBreak:error]: Link break detected on Fibre Channel target HBA 2c with event status 1 , topology type 1, status1 0x0, status2 0x0.
Wed Apr 12 03:42:09 +0200 [nxx-0x: fct_tpd_work_thread_0: scsitarget.hwpfct.linkUp:notice]: Link up on Fibre Channel target adapter 2c.
fcp.io.status:debug]: STIO Adapter:0e AEN 0x8048 (RECV_ERROR) MboxStatus1 0x1002 MboxStatus2 0xa1
- From
sfpshowlogs from Brocade switch:
RX Power: -1.9 dBm (647.5uW)
TX Power: -4.6 dBm (349.3 uW)
`show interface brief`logson Cisco switch connected to affected NetApp port reports switch port status as "errDisabled"
Interface Vsan Admin Admin Status SFP Oper Oper Port Logical
Mode Trunk Mode Speed Channel Type
Mode (Gbps)
fc1/27 3 auto off errDisabled swl -- -- -- --
show int transceiver detailoutput on Cisco switch reports low Tx power, indicating issues on the switch end sfp:
SFP Diagnostics Information:
Alarms Warnings
High Low High Low
Temperature 40.16 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.33 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 0.00 mA 12.00 mA 4.00 mA 11.20 mA 4.80 mA
Tx Power -40.00 dBm 5.00 dBm -12.20 dBm 2.00 dBm -8.20 dBm
Rx Power -0.49 dBm 5.00 dBm -15.20 dBm 2.00 dBm -11.20 dBm
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
- The Rx and Tx values for the port on the Cisco switch are displaying as optimal, and the port status is up.
fc2/42 is up
Temperature 38.33 C, Voltage 3.38 V, Current 6.54 mA, TxPower -6.08 dBm, RxPower -3.11 dBm
- The port on the switch end has been toggled, yet the Rx power on the FC port at the NetApp end remains low.
Tue May 28 23:35:39 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 (SUCCESS)
Tue May 28 23:35:57 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=Interface fc2/42 state updated to down
Tue May 28 23:35:57 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 ; shutdown (SUCCESS)
Tue May 28 23:41:05 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=Interface fc2/42 state updated to up
Tue May 28 23:41:05 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 ; no shutdown (SUCCESS)
- Low throughput on adapter in System Manager
- As part of troubleshooting below steps can be performed:
- Low RX on ONTAP usually indicates a hardware fault on the transmitting end (either switch/ patch panels)
- Perform cable testing along with patch panel to check if cable is healthy
- Swap the cable to a different open working port on switch end to see if the problem follows
- Clean the connection on the cable and on both SFPs
- VMware servers went into
Not respondingstate frequently. - Below are the error from storage end -
[?] Tue May 20 01:35:58 +0530 [cx-labs-bgl-aff-03: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:1a IO WQE failure, Handle 0x0, Type 8, S_ID: 3002xx, VPI: 3, OX_ID: 4D20, Status 0x3 Ext_Status 0x1d [?] Tue May 20 01:36:13 +0530 [cx-labs-bgl-aff-03: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:1a IO WQE failure, Handle 0x0, Type 8, S_ID: 3002xx, VPI: 3, OX_ID: 4051, Status 0x3 Ext_Status 0x1d
- Performance issue is observed on host end. Below are the errors reported on the host end:
2025-05-23T06:38:20.431Z cpu85:2098417)ScsiCore: 1823: Power-on Reset occurred on naa.600a098038314a71692454716472xxxx 2025-05-23T06:38:23.249Z cpu24:2098418)ScsiDeviceIO: 4115: Cmd(0x45d9d4a9b6c8) 0x8a, CmdSN 0x800e002e from world 2125982 to dev "naa.600a098038314a71692454716472xxxx" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0x6 0x29 0x0 2025-05-23T06:38:41.558Z cpu30:3060886 opID=f36de402)UserDump: 2823: hostd-worker: Userworld(hostd-worker) coredump complete.
