NetApp Knowledge Base
ONTAP error inconsistency between TCP metadata and socket send buffer
801
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • ONTAP
  • iSCSI
Issue
node run -node <node> netstat -s -p tcp
  • SACK is enabled on storage iSCSI interfaces
network tuning tcp show
Example :
event log show -severity ERROR
tcp.conn.inconsistent:  Inconsistency between TCP metadata and the socket send buffer occurred for the connection with local address and remote address . The inconsistency occurred while processing "[cc_cong_signal:506]". The connection is "NOT Reset".
New to NetApp?
