NetApp Knowledge Base
FCP target and path loss on several blades in a chassis
385
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9
  • HPE Synergy
  • Brocade Fabric OS 9.1
  • VMware ESXi
Issue
  • Sporadic and intermittent path and target loss on different ESXi hosts (blades in HPE Synergy chassis)
  • ONTAP confirms related initiators not being logged in. Affected initiators and LIFs may change every few minutes.
::*> fcp ping-igroup show -vserver SVM -igroup * -ext-status wwpn-not-logged_in
  (vserver fcp ping-igroup show)
          Igroup                     Logical    Node      Ping     Extended
Vserver   Name        WWPN           Interface  Name      Status   Status
SVM
          SYNERGYESXGRP1 20:00:xx:xx:xx:xx:xx:29 SVM_fc07 NODEA12 reachable wwpn-not-logged_in
          SYNERGYESXGRP2 20:00:xx:xx:xx:xx:xx:09 SVM_fc07 NODEA12 reachable wwpn-not-logged_in
          SYNERGYESXGRP4 20:00:xx:xx:xx:xx:xx:01 SVM_fc02 NODEA11 reachable wwpn-not-logged_in
          SYNERGYESXGRP4 20:00:xx:xx:xx:xx:xx:01 SVM_fc04 NODEA12 reachable wwpn-not-logged_in
          SYNERGYESXGRP7 20:00:xx:xx:xx:xx:xx:31 SVM_fc02 NODEA11 reachable wwpn-not-logged_in
          SYNERGYESXGRP8 20:00:xx:xx:xx:xx:xx:31 SVM_fc04 NODEA12 reachable wwpn-not-logged_in
  • Sometimes initiators are confirmed as logged in, but related host still misses target and has dead paths
  • WQE with Ext_Status 0x16 errors in EMS / event log show
fcp.io.status: STIO Adapter:2a IO WQE failure, Handle 0x5, Type 8, S_ID: 10902, VPI: 259, OX_ID: 24C, Status 0x3 Ext_Status 0x16
  • FC Host bus target adapter resets due to command termination hung with SRAM dumps (likely but not necessarily on multiple storage controllers)
::> event log show -severity debug -event *fcp.io.status*hung*|*SRAM*
Time                Node             Severity      Event
12/21/2022 12:44:48 NODEA12          DEBUG         scsitarget.fcp.dump: FCP target SRAM dump generated for adapter 2a, fct_tpd_check_hung_commands: Command termination hung. cmd:0xfffff80917a41c60 (state=0xa, flags=0x2,ctio_sent=2/2, RecvExAddr=0x1aec, OX_ID=0x72, RX_ID=0xffff, SID=0x10902)
12/21/2022 12:44:48 NODEA12          DEBUG         fcp.io.status: STIO Adapter:2a, found hung cmd:0xfffff80917a41c60(state=10, flags=0x2, ctio_sent=2/2,RecvExAddr=0x1aec, OX_ID=0x72, RX_ID=0xffff,SID=0x10902, Cmd[28], req_q_free:0)
12/21/2022 11:56:38 NODEA12          DEBUG         fcp.io.status: STIO Adapter:1a, found hung cmd:0xfffff8090d1a4010(state=5, flags=0x0, ctio_sent=1/1,RecvExAddr=0x14ef, OX_ID=0x264, RX_ID=0xffff,SID=0x10902, Cmd[2A], req_q_free:0)
12/21/2022 11:55:51 NODEA11          DEBUG         scsitarget.fcp.dump: FCP target SRAM dump generated for adapter 2a, fct_tpd_check_hung_commands: Command termination hung. cmd:0xfffff80917b392f8 (state=0xa, flags=0x2,ctio_sent=2/3, RecvExAddr=0x146e, OX_ID=0x178, RX_ID=0xffff, SID=0x10c03)
12/21/2022 11:55:46 NODEA11          DEBUG         fcp.io.status: STIO Adapter:2a, found hung cmd:0xfffff80917b392f8(state=7, flags=0x0, ctio_sent=1/2,RecvExAddr=0x146e, OX_ID=0x178, RX_ID=0xffff,SID=0x10c03, Cmd[8A], req_q_free:0)
5 entries were displayed.
  • On Brocade switch, increasing c3timeout on TX for host ports and RX for storage ports indicates end device congestion
  1. Run statsclear
  2. Wait 15 minutes
  3. Run porterrshow
Example:
FID128:admin> porterrshow 8-13
           frames        enc     crc     crc     too     too     bad     enc    disc    link    loss    loss    frjt    fbsy     c3timeout     pcs      uncor
         tx       rx      in     err     g_eof   shrt    long    eof     out    c3      fail    sync    sig                      tx      rx      err     err
   8:    4.8m    8.4m    0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0
   9:    1.1k    1.1k    0       0       0       0       0       0       0     717       0       0       0       0       0     717       0       0       0
  10:    0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0
  11:    0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0
  12:    3.9m    6.8m    0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0
  13:  976       1.2k    0       0       0       0       0       0       0     840       0       0       0       0       0     840       0       0       0
FID128:admin> porterrshow 20-23
  20:    6.7m    7.6m    0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0
  21:    3.9m    2.5m    0       0       0       0       0       0       0     518       0       0       0       0       0       0     259       0       0
  22:    3.9m    2.5m    0       0       0       0       0       0       0     974       0       0       0       0       0       0     487       0       0
  23:    6.4m    3.0m    0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0       0
New to NetApp?
