NetApp Knowledge Base
What is the guidance on the recommended values for Latency (ms) and IOPS?
569
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
Answer
  • From a performance perspective, NetApp does not have specific recommended values or upper limits.
  • There are no definitive criteria such as "if it is below this threshold, it is considered normal."
  • You should use the current configuration and the conditions under which stable workloads are operating normally as your baseline.
