NetApp Knowledge Base
Why would AIQUM report a higher delay than other performance monitoring tools?
903
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • ActiveIQ Unified Manager (AIQUM)
  • ActiveIQ PAS (AIQ PAS)
Answer
AIQUM has a differenty way to report the latency than the other performance monitoring tools. This will lead to a significant higher delay from a Service/Delay center in AIQ PAS if there is any unaccounted latency.
AIQUM:
  1. It calculates the raito of different Service/Delay centers with the total calculated latency
  2. Then it use that ratio to display the contribution of a Service/Delay center to the actual total measured latency
The rest tools (CLI/AIQ PAS/Perfstat):
All these tools will display the actual measured latency
Example:
  • Out of the 58ms total latency, only 772us is properly accounted.
  • Only 487us is accounted under Cluster (Cluster Interconnect)
  • But, AIQUM will report the 58ms total latency and 36.5ms delay from Cluster.
    • The ratio of the delay from Cluster against the total latency is 487.00us / 772.00us ~= 63%
    • The calculated delay from Cluster is 58ms x 63% ~= 36.5ms
> qos statistics volume latency show
Workload            ID    Latency    Network    Cluster       Data       Disk    QoS Max    QoS Min      NVRAM
test_volume111  41567   772.00us   188.00us   487.00us    67.00us        0ms        0ms        0ms    30.00us
> qos statistics volume performance show
Workload            ID     IOPS       Throughput    Latency
test_volume111  41567       17        86.74KB/s    58.00ms
Notes:
  • AIQUM displays a cooked number for each Delay/Service center
  • When there is no gap between the total latency and the sum of all the Delay/Service centers, what AIQUM displays agrees with the other tools
  • When there is a significant delay between the total latency and the sum of all the Delay/Service centers, what AIQUM displayes could be distorted
