NetApp Knowledge Base
Slow SnapMirror performance and low throughput do to BRE/LRSE Throttling
517
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
Perf
Last Updated:
Applies to
  • ONTAP 9
  • SnapMirror
  • Block Replication Engine (BRE)
  • Logical Replication with Storage Efficiency (LRSE)
Issue
  • Low throughput during SnapMirror transfers due to Replication Engine throttling
  • Verify that the following items have been eliminated as potential issues first
    • Avoid running to many SnapMirror transfers at once
    • Spread out the SnapMirror transfers to reduce impact
    • Initiate SnapMirror transfers during times of lower user workloads and lower CPU activity
    • Check to see if the global throttling mechanism is in use for SnapMirror
    • If the replication traffic is going over a WAN, you can enable Network Compression for those SnapMirror policies to improve performance
      • Note: Do not use network compression in cases of already high CPU utilization
New to NetApp?
