NetApp Knowledge Base
Latency reported as ICMP packets dropped by storage interface (LIF)
998
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • SMB
  • NFS
Issue
  • The host tries to ping the cifsserver and on receiving no response, error is reported as below:
05/12/2023 11:54:56:251 | 03 | 040 | p5136 | t1096 | GetVolumeStatus | DiskMonitorThread.cpp(117) | Successful attempt to ping the location: \\cifsserver.LOCAL\file01
05/12/2023 11:54:56:380 | 03 | 015 | p5136 | t1096 | TestWriteAccess | DiskMonitorThread.cpp(32) | Fail test write access: A device attached to the system is not functioning.
  • Flood ping using -f in linux to a iscsi lif reports packet drops in the result
  • icmp.ping.throttle occurs when the system receives a burst of ICMP ping packet within a one-second interval.
  • EMS log shows the following events:
Wed Nov 29 12:54:43 +0530 [NODE-01: kernel: icmp.ping.throttle:notice]: icmp_input: The system dropped 2180 ping packets after limiting the packets to 200 per second.
Wed Nov 29 13:04:44 +0530 [NODE-01: kernel: icmp.ping.throttle:notice]: icmp_input: The system dropped 4522 ping packets after limiting the packets to 200 per second.
Wed Nov 29 13:14:46 +0530 [NODE-01: kernel: icmp.ping.throttle:notice]: icmp_input: The system dropped 2013 ping packets after limiting the packets to 200 per second.
Wed Nov 29 13:24:47 +0530 [NODE-01: kernel: icmp.ping.throttle:notice]: icmp_input: The system dropped 3477 ping packets after limiting the packets to 200 per second.
New to NetApp?
