NetApp Knowledge Base
What is volume show option Is Directory Index Transfer Enabled and what does this setting control?
24
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9.17.1 and later
  • volume show
  • Storage System Performance
  • SnapMirror Replication
Answer
  • Is Directory Index Transfer Enabled controls whether directory index files are included in SnapMirror replication.
  • The behavior depends on the setting:
    • true: Directory index files are transferred by SnapMirror and are replicated to the destination volume.
    • false: Directory index files are excluded from SnapMirror transfers and will not be created on the destination volume.
  • This setting is relevant when directory metadata consistency or directory access performance is important in a replicated environment.
Additional Information
additionalInformation_text
