NetApp Knowledge Base
What is ownblocks_calc scanner and how does it work?
2,192
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
Answer
  • The snapshot is safely written to disk on the first consistency point after a snapshot command is issued.
  • The size etc are computed after the phase by a slow ownblocks_calc scan that is deliberately throttled.
  • We run the ownblocks_calc when a snapshot is created, or blocks used complete (kicked off after a snapshot deletion) or if a list command is executed.
  • Further, since we only invalidate the values when blks used runs, it is possible that the values become quite stale until blks used finishes.
  • And blks used can get restarted every time a new delete occurs so it might take a long time for the ownblocks to get a chance to run & update the values, but there is no data integrity issue as far as the snapshot itself is concerned.
  • Running wafl scan ownblocks_calc from nodeshell forces us to recalculate own blocks values through the scanner even if they are valid/scan has not been kicked off through blocks used which is why you see updated values once this is executed.
Example output:
::> set advanced
::*> run local wafl scan status volume_name
Volume volume_name:
Scan id                   Type of scan     progress
  843657    block ownership calculation     block 19994 of 30803
