NetApp Knowledge Base
Volume move stuck at 92 percent due to snaplock-locked snapshot in ONTAP
31
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • SnapLock Compliance volumes
Issue
  • A vol move operation for a SnapLock DP volume is stuck at 92% in the “finishing” phase and does not complete.
  • The job status reports:
Cluster::*> vol move show -state warning -instance
Vserver Name: svm1
Volume Name: vol1
Volume Instance UUID: xxxxxxxx-xxxx-xxx-xxx-xxxxxxxxx
Specified Action For Cutover: defer_on_failure
Specified Cutover Attempts: 3
Specified Cutover Time Window: 30
Time User Triggered Cutover: -
Time Move Job Last Entered Cutover: Fri Aug 28 23:28:49 2026
Cutovers Attempted: 1
Destination Aggregate: aggr1_dest
Destination Node: Node1_dest
Detailed Status: Cutover Completed::Volume move job finishing move
Error: Deleting Snapshot copy: Illegal operation on snapshot locked by SnapLock
Estimated Time of Completion: Sat Aug 29 03:17:42 2026
Internal Progress of Move: Cutover Completed::Volume move job finishing move
  • Attempts to abort the move or stop the job fail with errors such as Volume is busy:
Cluster::*> vol move abort -volume vol1 -vserver svm1
Error: command failed: Volume is busy.
  • The reference snapshot will remain present and cannot be deleted, with ONTAP event logs reporting repeated failures to delete the snapshot due to SnapLock compliance.
New to NetApp?
