NetApp Knowledge Base
Volume efficiency start failing with error Compression is not enabled. Use of options -a and -b is not valid
635
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9.8 and above
  • Storage Efficiency
  • Temperature Sensitive Storage Efficiency (TSSE)
Issue
When trying to rescan the volume for efficiency savings including the snapshot and/or shared-blocks, following error is reported:
cluster01::> set -privilege advanced
cluster01::*> vol efficiency start -volume vol1 -scan-old-data true -snapshot-blocks true
Warning: This operation scans all of the data in volume "vol1" of Vserver "svm1". It might take a significant time, and degrade performance during that time.
         Use of "-snapshot-blocks|-b" option can increase space usage as data which is part of Snapshot will be compressed.
Do you want to continue? {y|n}: y
Error: command failed: Failed to start efficiency on volume "vol1" of Vserver "svm1": Compression is not enabled. Use of options -a and -b is not valid.
cluster01::*>
New to NetApp?
