NetApp Knowledge Base
Takeover not possible during ONTAP Upgrade due to Storage failover interconnect error and Disk inventory not exchanged
90
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • AFF-A20
  • ONTAP 9
  • Automated Non-Disruptive Upgrade (ANDU)
Issue
  • During ANDU, one of the nodes in the HA pair is upgraded to ONTAP 9.18.1, while the partner node remains at 9.16.1Px.
  • The upgrade process is paused with the following takeover was not possible error:
Cluster::> storage failover show
                              Takeover
Node           Partner        Possible State Description
Node-A              Node-B    false    Waiting for Node-B, Takeover is
                                       not possible: The version of
                                       software running on each node of the
                                       SFO pair is incompatible, Storage
                                       failover interconnect error, NVRAM
                                       log not synchronized, Disk inventory
                                       not exchanged
Node-B              Node-A    false    Waiting for Node-A, Takeover is
                                       not exchanged
  • The HA interconnect links are up, but the RDMA connection is down:
::*> system ha interconnect status show
                       Node: Node-A
              Link 0 Status: up
              Link 1 Status: up
           Is Link 0 Active: true
           Is Link 1 Active: true
         IC RDMA Connection: down
                       Node: Node-B
              Link 0 Status: up
              Link 1 Status: up
2 entries were displayed.
    • The following errors are seen in the event logs:
    [Node-A: cfdisk_config: cf.diskinventory.sendFailed:debug]: params: {'reason': 'HA Interconnect down', 'errorCode': '0'}
    [Node-B: cfdisk_config: cf.diskinventory.sendFailed:debug]: params: {'reason': 'HA Interconnect down', 'errorCode': '0'}
    • Reseat of the HA cables does not change the RDMA connection status.
    • Manual takeover fails with the following error:
    ::> storage failover takeover -ofnode Node-A
    Warning: A takeover will be initiated. When the partner node reboots, a giveback
             will be automatically initiated. Do you want to continue?
              {y|n}: y
    Error: command failed: Failed to initiate takeover. Reason: Disk inventory infomation not recieved yet
    • An attempt to allow disk inventory mismatch and version mismatch also fails with the following error:
    ::*> storage failover takeover -ofnode Node-A -allow-disk-inventory-mismatch true -option allow-version-mismatch
              {y|n}: y
    Warning: Initiating a takeover while node cannot see some of the partner disks
             is not recommended. Do you want to continue? {y|n}: y
    Warning: Initiating a takeover while the partner is running a mismatched ONTAP
             version is not recommended, unless you are performing a nondisruptive
             upgrade or downgrade. Do you want to continue? {y|n}: y
    Error: command failed: Failed to initiate takeover. Reason: Partner is not UP .
    New to NetApp?
