NetApp Knowledge Base
SyncMirror error: Current disk pool assignments do not guarantee fault isolation for aggregates mirrored with SyncMirror
334
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • Local Sync Mirror
  • Advanced Disk Partitioning (ADP)
Issue
Local SyncMirror creation fails with an error as below.
aggr mirror -aggregate <aggregate> -mirror-partitionlist <partition_list> -simulate true
Error: command failed: Aggregate mirroring would fail for aggregate "<aggregate>" on node "<node>". Reason: Current disk pool assignments do not guarantee fault isolation for aggregates mirrored with SyncMirror. Other disks in the loop are in a different pool than disks: "disk_id", "disk_id". Use "disk show -v" to view and "disk assign" to change the disk pool assignments.
New to NetApp?
