NetApp Knowledge Base
Storage failover output shows difference in HA nodes when single shelf removed
128
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF systems
Issue
  • In FAS/AFF systems, storage failover show displays different output in HA nodes when remove single disk shelf.
    • When remove cable from SAS port 0a,5b in node-01, it shows:
      ::> storage failover show
                                    Takeover
      Node           Partner        Possible State Description
      Node-01        Node-02        -        Kernel loaded
      Node-02        Node-01        false    In takeover
    • When remove cable from SAS port 0c,5d in node-02, it shows:
                                    Takeover
      Node-01        Node-02        false    Normal giveback not possible:
                                             partner missing file system disks
      Node-02        Node-01        -        Waiting for giveback
  • Systems configuration in normal:
    • Node-01:
      • SYSCONFIG-A:
        slot 0: SAS Host Adapter 0a (Broadcom SAS3616W rev. 2, SAS, <UP>)
            01.23: NETAPP   X371_S164A960ATE NA54 915.4GB 520B/sect (S5xxxxxxxxxx)
            Shelf 1: DS224-12  Firmware rev. IOM12B A: 0141  IOM12B B: 0141
        slot 5: SAS Host Adapter 5b (Broadcom SAS3616W rev. 2, SAS, <UP>)
      •  STORAGE-FAILOVER.XML:
Node    Node-01
Partner Name    Node-02
Local Mailbox Disks    1.1.12.P3, 1.1.13.P3, 1.1.14.P3
Partner Mailbox Disks    1.1.0.P3, 1.1.1.P3, 1.1.2.P3
SYSCONFIG-R
Aggregate aggr0_Node-01 (online, raid_dp, fast zeroed) (block checksums)
  Plex /aggr0_Node-01/plex0 (online, normal, active, pool0)
    RAID group /aggr0_Node-01/plex0/rg0 (normal, block checksums)
      RAID Disk    Device      HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity     0a.01.12P3    0a    1   12  SA:A   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      parity      5b.01.13P3    5b    1   13  SA:B   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        0a.01.22P3    0a    1   22  SA:A   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        5b.01.23P3    5b    1   23  SA:B   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        0c.11.12P3    0c    11  12  SA:A   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        5d.11.13P3    5d    11  13  SA:B   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        0c.11.20P3    0c    11  20  SA:A   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        5d.11.21P3    5d    11  21  SA:B   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
    • Node-02:
      • SYSCONFIG-A:
        slot 0: SAS Host Adapter 0c (Broadcom SAS3616W rev. 2, SAS, <UP>)
            11.23: NETAPP   X371_S164A960ATE NA54 915.4GB 520B/sect (S5xxxxxxxxxx)
            Shelf 11: DS224-12  Firmware rev. IOM12B A: 0141  IOM12B B: 0141
        slot 5: SAS Host Adapter 5d (Broadcom SAS3616W rev. 2, SAS, <UP>)
        Node    Node-02
        Partner Name    Node-01
        Local Mailbox Disks     1.1.0.P3, 1.1.1.P3, 1.1.2.P3
        Partner Mailbox Disks    1.1.12.P3, 1.1.13.P3, 1.1.14.P3
      • SYSCONFIG-R:
Aggregate aggr0_Node-02 (online, raid_dp, fast zeroed) (block checksums)
  Plex /aggr0_Node-02/plex0 (online, normal, active, pool0)
    RAID group /aggr0_Node-02/plex0/rg0 (normal, block checksums)
      dparity     0a.01.0P3    0a    1   0   SA:B   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      parity      5b.01.1P3    5b    1   1   SA:A   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        0a.01.10P3    0a    1   10  SA:B   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        5b.01.11P3    5b    1   11  SA:A   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        0c.11.0P3    0c    11  0   SA:B   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        5d.11.1P3    5d    11  1   SA:A   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        0c.11.8P3    0c    11  8   SA:B   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
      data        5d.11.9P3    5d    11  9   SA:A   0   SSD   N/A 9594/19650048     9602/19666432 (fast zeroed)
New to NetApp?
