NetApp Knowledge Base
Storage efficiency not correct applied after conversion to Flexgroup
384
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • Flexgroup conversion
Issue
  • After converting a Flexvol to a Flexgroup, some of the flexgroup constituents have different storage efficiency settings:
cluster1::*> sis show myvolume*
Vserver    Volume           State     Status      Progress           Policy
svm0       myvolume         Idle                    -                Staggered Policy
                                        Mixed
svm0       myvolume__0001 Idle                     Idle for 00:00:00  -
                                        Disabled
svm0       myvolume__0002 Idle                     Idle for 119:14:59 auto
                                        Enabled
3 entries were displayed.
  • Trying to enable storage efficiency on all components fail:
::> set d
::*> sis modify myvolume__0001 -policy auto
Error: command failed: Failed to modify efficiency configuration for volume "myvolume__0001" of Vserver "svm0": Operation is not configured.
  •  AUDIT-MLOG-TXT.GZ in ASUP:
filer1:admin :: volume efficiency on -volume volumename__0001 :: Pending
filer1:admin :: volume efficiency on -volume volumename__0001 :: Success
filer1:admin :: volume efficiency start -volume volumename__0001 :: Pending
filer1:admin ::volume efficiency start -volume volumename__0001:: Error: Failed to start efficiency on volume "volumename__0001" of Vserver "vservername: Operation is not configured.
filer1:admin :: volume efficiency on -volume volumename :: Pending
filer1:admin ::volume efficiency on -volume volumename:: Error: [Job 37476] Job failed: The efficiency operation was successful but the efficiency state of the FlexGroup has not finished updating. Wait a few minutes, and then checkthat the efficiency state of the volume is "Enabled" using the "volume efficiency show -vserver <vservername> -volume <volumename> -fields state" command. For further assistance, contact technical support.
New to NetApp?
