NetApp Knowledge Base
SnapDiff v3 Does Not Work with Commvault:  “API not found” Error
168
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • NetApp ONTAP 9.16.1P11 and later
  • AFF-A250 (All Flash FAS)
  • Commvault 11.40 and later
  • SnapDiff v3 integration
Issue
SnapDiff v3 Does Not Work with Commvault: “API not found” Error When Using Cluster Management LIF
When attempting to configure and test SnapDiff v3 backups with Commvault (using cluster-based configuration), the following error is returned when using the cluster management LIF:
Log Output:
$ curl -u snapdiff -k https://hostname/api/snapdiff/volumesEnter host password for user 'snapdiff':{  "error": {    "message": "API not found",    "code": "3"  }}
  • SnapDiff v3 login fails and snapshots cannot be created.
  • Commvault UI may show “cluster-based” configuration, but authentication fails.
New to NetApp?
