NetApp Knowledge Base
ONTAP revert not possible due to storage error
55
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Upgrade/Revert
Issue
Revert failed due to storage error:
cluster1::*> system node revert-to -node cluster1n1 -version 9.7
Warning: This command reverts cluster configuration ONLY. The File system on every controller in the cluster must be reverted by running "revert_to" from the
         nodeshell on every controller. Example: run local revert_to 9.7
Do you want to continue? {y|n}: y
         Warning: Existing NFSv4.2 mounts will not be accessible after reverting from release 9.8.
Error: command failed:
       You must clean up configuration errors in order to perform revert.
        Command to describe errors: "storage errors show"
New to NetApp?
