NetApp Knowledge Base
ONTAP revert fails with volume recovery queue is not empty
174
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
ONTAP 9 revert
Issue
  • ONTAP revert fails:
::*> system node revert-to -node node-01 -check-only true -version 9.13
Error: command failed: The revert check phase failed. The following issues must be resolved before revert can be completed.
Disable snapshot policies.
Command to list snapshot policies: "snapshot policy show".
Command to disable snapshot policies: "snapshot policy modify -vserver * -enabled false"
Volume recovery queue is not empty. Contact technical support for assistance.
  • All snapshot policies are disabled:
::> volume snapshot policy show -enabled true
There are no entries matching your query
New to NetApp?
