NetApp Knowledge Base
ONTAP ANDU pauses with Volume limits check failed on destination node
267
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FAS and AFF Systems
  • NAS protocol in use (NFS/CIFS)
  • Automated Nondisruptive Upgrade (ANDU)
Issue
  • During an ANDU, the process pauses with a message seen on the node that is attempting to giveback the SFO aggregates to the HA partner that has just rebooted with the new ONTAP version:
Thu Jun 23 11:51:59 -0700 [Cluster01-01: cf_giveback: wafl.arl.vol.limitChkFailed:error]: Aggregate 'aggr1': Volume limits check failed on destination node Volume count (1553) exceeds system limit (1000)..
  • Partial SFO giveback is observed:
Cluster01::*> aggr show -node Cluster01-01
Aggregate Size     Available Used% State   #Vols  Nodes            RAID Status
aggr1     352.1TB  144.7TB   59%   online  206    Cluster01-01     raid_tec, normal
aggr2     352.1TB  122.2TB   65%   online  347    Cluster01-01     raid_tec, normal
aggr3     352.1TB  143.9TB   59%   online  213    Cluster01-01     raid_tec, normal
aggr5     184.1TB  39.22TB   79%   online  223    Cluster01-01     raid_tec, normal
  • Note the number of volumes for the given-back aggregates = (206+347+213+223) = 989.
  • The remaining aggregates still on the HA partner:  aggr4 & aggr6 had 399 and 401 volumes respectively, both which would exceed the maximum number of volumes for this platform (1000 for the FAS9000/AFF-A700 in this case).
New to NetApp?
