NetApp Knowledge Base
Node unable to monitor cluster switches due to incorrect network configuration on switch
426
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Cluster Switch Health Monitor (CSHM)
  • Cisco cluster switches
  • Broadcom cluster switches
Issue
  • Node reports a health alert stating that the cluster switch IP address is not reachable:
cluster::> system health alert show
               Node: NodeA
           Resource: cluster-sw1
           Severity: Major
    Indication Time: Thu Aug 18 22:42:33 2022
           Suppress: false
        Acknowledge: false
     Probable Cause: Ethernet switch "cluster-sw1" with IP address
                     "10.X.X.1" is not reachable via SNMP. Incorrect
                     SNMP community string might be configured on the
                     Ethernet switch.
  • Cluster switch is not monitored by the CSHM:
cluster::> system switch ethernet show
Switch                      Type               Address          Model
cluster-sw1(xxxxxxxxxxx)    cluster-network    10.X.X.1         NX3132V
     Serial Number: xxxxxxxxxxx
      Is Monitored: false
            Reason: IP address not reachable
  Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.0(3)I4(1)
    Version Source: CDP
  • Cluster switch management IP address is not pingable.
cluster::> ping -node NodeA -destination 10.X.X.1
no answer from 10.X.X.1
  • Switch MAC address is not found in the ARP table.
cluster::> set -privilege advanced
cluster::*> network arp active-entry show -node NodeA -remotehost 10.X.X.1
There are no entries matching your query.
New to NetApp?
