NetApp Knowledge Base
Node in switched cluster not serving data after power maintenance
1,012
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • ONTAP
  • Cluster interconnect switches
Issue
  • After scheduled power maintenance, nodes are powered up but one or more nodes do not serve data.
  • Aggregates on non-working nodes report state unknown in storage aggregate show:
Aggregate     Size Available Used% State   #Vols  Nodes            RAID Status
root_n1          -         -     - unknown      - cluster1-01      -
aggr_n1          -         -     - unknown      - cluster1-01      -
root_n2     3.04GB   152.4MB   95% online       1 cluster1-02      raid_dp,
        normal
aggr_n2    31.77GB   31.75GB    0% online       1 cluster1-02      raid_dp,
  • Cluster ports are link down in network port show:
        Ignore
                                                  Speed(Mbps) Health   Health
Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
e0a       Cluster      Cluster          down 9000  auto/-     -        false
e0b       Cluster      Cluster          down 9000  auto/-     -        false
  • Output of storage failover show indicates nodes are waiting for cluster applications to come online:
                              Takeover
Node           Partner        Possible State Description
cluster1-01    cluster1-02    true     Connected to cluster1-02
cluster1-02    cluster1-01    true     Connected to cluster1-01.
                                       Waiting for cluster applications to
                                       come online on the local node.
                                       Offline applications: vldb, vifmgr,
                                       bcomd, crs, scsi blade, clam.
  • First node to come up will typically be cluster master and serving data, whereas other nodes are powered up but cluster apps are offline and not serving data.
New to NetApp?
