NetApp Knowledge Base
Is it possible to create a volume using different aggregates in ONTAP?
282
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Answer
  • Yes, it is possible. It is a Flexgroup volume; a volume that spans across different aggregates in the cluster.
  • By choosing "Distribute volume data across cluster (FlexGroup)" in System Manager when you are creating the volume, ONTAP will automatically select the aggregates to provision the storage for the Flexgroup volume.
New to NetApp?
