NetApp Knowledge Base
Is it necessary to set the same compression algorithm in both FlexCache and Origin volume when origin volume set with zstd compression?
103
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
Core
Last Updated:
Applies to
  • ONTAP 9
  • FlexCache Volume
  • Temperature-sensitive storage efficiency(TSSE)
Answer
No. It is not necessary to set the same compression algorithm in both FlexCache and Origin volume.
  • zstd compression is only supported for TSSE.
  • The cache volume will default to file compression (i.e. default mode). This is because mostly the cache volumes are used for improving performance of reads and cache hot data; hence cold data compression cannot provide any additional benefits.
Additional Information
additionalInformation_text
