NetApp Knowledge Base
IO recovery delay during node failure test with 'system power off' command
44
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Hardware-Assisted Takeover (HWassist)
Issue
During a node failure test conducted using the system power off command from the BMC/SP, IO recovery time is significantly longer compared to recovery time after manually triggering a panic.
Example:
  • IO recovery time after system power off: Up to 137 seconds
  • IO recovery time after panic: Up to 54 seconds
New to NetApp?
