NetApp Knowledge Base
How to configure Aggregate and Volume Nearly Full and Full Thresholds in ONTAP
14,008
Visibility:
Votes:
14
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Volume Thresholds
  • Volume Nearly Full Threshold Percent specifies the percentage at which the volume is considered nearly full, and above which an EMS warning will be generated.
    • The default value is 95%.
    • The maximum value for this option is 99%.
    • Setting this threshold to 0 disables the volume nearly full space alerts.
  • Volume Full Threshold Percent specifies the percentage at which the volume is considered full, and above which a critical EMS error will be generated.
    • The default value is 98%.
    • The maximum value for this option is 100%.
    • Setting this threshold to 0 disables the volume full space alerts.
Netapp::> volume show -volume vol1 -fields space-nearly-full-threshold-percent,space-full-threshold-percent
vserver volume space-nearly-full-threshold-percent space-full-threshold-percent
svm1    vol1   95%                                 98%
Aggregate Thresholds
  • Aggregate Nearly Full Threshold Percent
    • This optionally specifies the percentage at which the aggregate is considered nearly full, and above which an EMS warning will be generated.
    • Setting this threshold to 0 disables the aggregate nearly full space alerts.
  • Aggregate Full Threshold Percent
    • This optionally specifies the percentage at which the aggregate is considered full, and above which a critical EMS error will be generated.
    • Setting this threshold to 0 disables the aggregate full space alerts.
Netapp::> aggr show -aggregate aggr1 -fields space-nearly-full-threshold-percent,space-full-threshold-percent
aggregate space-nearly-full-threshold-percent space-full-threshold-percent
aggr1     95%                                 98%
New to NetApp?
