NetApp Knowledge Base
EMS mgmtgwd.vreport.nodesUnreachable is reported during hardware maintenance
96
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • AFF-A700
  • Some nodes in the same cluster are under hardware maintenance
  • CVO (GCP/AZURE)
Issue
  • EMS-LOG-FILE.GZ reports mgmtgwd.vreport.nodesUnreachable error:
[node01: mgwd: mgmtgwd.vreport.nodesUnreachable:error]: Vreport encountered some unreachable nodes. The report may be incomplete.
  • MGWD.GZ  reports that the other nodes in the same cluster are unreachable
Example: MGWD.GZ in node01 reports that node03 is unreachable while the maintenance of node03
[kern_mgwd:info:3731] 0x82f58e300: 0: WARNING: tables::vreport: Skipping unreachable node: node03
[kern_mgwd:info:3731] 0x82f58e300: 0: WARNING: tables::vreport: Following Nodes were not reachable: node03
[kern_mgwd:info:3731] Warning: "Vreport" could NOT retrieve required information from the following nodes in the cluster node03.
[kern_mgwd:info:3731] Some discrepancies might not have been reported by "Vreport"
New to NetApp?
