During ONTAP upgrade system image modify command fail due to offline volume
Applies to
ONTAP 9
Issue
system image modify command failed.::*> system image modify -node node-01 -image image1 -isdefault true
Error: command failed: Cannot change default software image. One or more
volumes are not online or restricted or are DP volumes in a transient
state. Use the "volume show -state !online -node <node-name> -state
!restricted" command to list them. For DP volumes in a transient state
which is indicated by the state "-", wait for them to come online and
retry the command.
