NetApp Knowledge Base
Does "volume move" need aggregate capacity larger than volume size?
44
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • volume move command
Answer
  • If the volume is thick provisioning, it is Yes.
  • If the volume is thin provisioning, it is No and it needs the capacity larger than the used volume size.
Additional Information
additionalInformation_text
