NetApp Knowledge Base
Does ONTAP suport enabling NVE with SED on same node
194
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • AFF and FAS
  • ONTAP 9
  • NetApp Volume Encryption (NVE)
  • Self-Encrypting Drives (SED)
Answer
Yes, ONTAP support enabling NetApp Volume Encryption (NVE) with Self-Encrypting Drives (SED) on the same node.
You can use NVE with hardware-based encryption to "double encrypt" data on self-encrypting drives.
This means that you can have both NVE and SEDs enabled on the same system, providing an additional layer of security for your data.
Refer to:
Additional Information
additionalInformation_text
